On the list:
Macbook 1.83ghz core 2 duo
2x Mac Mini
At the moment I have a launch edition Macbook 1.8ghz/512mb ram with the original core duo chip but seeing as my sister needs a new laptop, i've decided to give her my one and then get myself one of the new core 2 duo ones and fill it with 2gb of ram
Hopefully should speed things up for me as with 512mb I feel switching between apps slow at times.
The Mac Mini, I haven't used these before but for what they are, the price seems great value, especially with HE discount. One of the Minis will be used as my dad's new office machine and the other one will be used as a box which just streams remote cctv footage - overkill maybe, but for the price there isn't a much cheaper option.
The only thing is, I have to install XP on both the Mac Mini's, i'm going to have a 1.66ghz with 512mb ram for the streaming box but my question lies with the one my dad will use. Will running XP really bog down the system, is 1.66ghz fine for Office XP and MS Money? Should I add another 512mb to bring it up to 1gb?
Basically I need guidance as to what I should do as i've been using Mac OS X on my 1.83ghz Macbook and Office XP runs ok, if only a little slow in loading up. Will it run similar/faster with XP?
Thanks
2x Mac Mini
Hopefully should speed things up for me as with 512mb I feel switching between apps slow at times.The Mac Mini, I haven't used these before but for what they are, the price seems great value, especially with HE discount. One of the Minis will be used as my dad's new office machine and the other one will be used as a box which just streams remote cctv footage - overkill maybe, but for the price there isn't a much cheaper option.
Thanks
How can they ever find out and why does it bother you?
