Hey, been lurking on the fourm for a while but only just managed to get registered
Spent a while researching each part but think I'm pretty much ready to order.
Will everything in the basket fit in the case? Also is the 120mm akasa viper worth buying?
Anyone had any experience with the overclocked bundles or is it worth just buying the parts seperately and overclocking it myself?
Tell me what you think of the spec and any changes you would make would be appreciated aswell.
Cheers
Cheers
