ok i am about to order now could use 1 more check to see if everything is ok!
after all the advice i have been given on these forums this is the final spec i would like to go for!
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2
Antec Nine Hundred Ultimate Gaming Case
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
I am told the case i will be using has good airflow and i will be able to overclock with ease, however in a month or so i will be getting a new heatsink when i want to overclock some more.
Thanks for advice!
Thanks for advice!
