About to order.... quick check.
17 Mar 2005
Home
Anyone got any adjustments you would recommend?
Gigabyte GA P35C-DS3
Intel Core 2 Duo, E8400
768MB XFX 8800GTX, Extreme
450W Corsair VX Series
get the TX650 for £10 more i say
im not sure if the VX450 will be running close to its full potential with that rig but i would rather spend a bit more for peace of mind
How much is the 8400 and the 8800 GTX? I'd suggest you downgrade slightly (and then just overclock) and with the money you save, put it towards the 9800 GX2.
i'd swap the p35c-ds3r to the p35-ds3r version, and would update the psu if you're going for the GTX as they are a bit power hungry.
