About to purchase - Final check
13 Sep 2012
As the title says I'm about to get the below items, is there anything you guys would change or recommend an alternative for?
Current setup is:
FX4100
GA-880GM-USB3
4GB RAM
XFX Pro Series 650W
Giga 7850 2GB
Agility 3 90GB
WD 750GB
Pioneer Bluray drive
Current case is a budget competitors case :(
YOUR BASKET
1 x Cooler Master CM-690 II Advanced USB3.0 Dominator Case - Black/White £59.99
1 x **B Grade** Thermalright HR-02 Macho CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) £21.00
1 x Arctic Cooling MX-4 Thermal Compound (4g) £8.99
1 x Akasa AK-TC TIM Clean CPU & Heatsink Cleaner £5.99
Total : £95.96 (includes shipping : FREE).
olivier renault what do you reckon about the case?
Yeah, good. Cooling can be improved. Used to be an old favourite on the forums. Very ubiquitous, upgradable, well built and easy to find info.
Other options are the Zalman Z9+, Z11, Bitfenix Shinobi's, Corsair 200R / 300R.
Should fit the HR-02 fine.
Cool, personally i prefer the look of the 690 so I think I'll go for that :) and as Papalazaru said take the bottom cage out.
hows it for water cooling in for future referece?
