Hello everyone.
I'm nearly ready to hit buy. Can you check the configuration that I have selected and advise me if I should be making any last minute changes. I can spend an extra £100 if I need to. Is the memory/motherboard ok? Should I pick a different model 780Ti?
I'm also 50/50 between the ASUS and the http://www.overclockers.co.uk/showproduct.php?prodid=MO-187-SA. What do you think?
Thanks in advance.
OcUK Pro Gamer X65i Intel Z87 Full-Tower - Gaming PC Configurator
Options applied to the above product:
- Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW)
- Stage 4 Intel: Overclock of CPU - 4.5GHz Overclock - Haswell K Edition Processors Only
- Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
- Corsair Hydro H80i High Performance Liquid CPU Cooler
- Asus Z87 Maximus VI Hero
- TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01)
- KFA2 Geforce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card
- Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
- Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD
- OcUK 20x DVD±RW SATA ReWriter (Black) - OEM
- Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply
- Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614)
- BitFenix Alchemy Premium Modding LED Strip - Connect Red 60cm
- BitFenix Spectre PRO 120mm Fan Red LED - Black
- Asus PB278Q 27" Professional LED Multimedia Monitor - Black
- Standard Build Systems - Approximately 5-7 working days
Total Cost £2358.65
Thanks in advance.
Total Cost £2358.65
