About to strangle mechanic
28 Dec 2004
Derry
Paid to have the clutch replaced on wifes car, pretty much as soon as we got it back I noticed clear fluid patches on the drive. Turns out he never changed the driveshaft seals and now suddenly, after him wrestling the new clutch in the nearside seal's leaking! Unlucky coincidence that I should suck up and pay for him to fix or should I excerpt pressure on his windpipe until he agrees to finish the job we originally paid for?
It's highly unlikely to be a coincidence since the driveshafts need to be removed to get the gearbox out. He has probably damaged the seal getting the driveshaft back into the diff.
Correct, its clear if new, but would it be clear on a car old enough for a clutch change?
Either way, i wouldnt expect to have to change seals as a given when getting the shafts out unless its a known issue with those cars
Should change the seals when you remove driveshafts anyway once you pull them they are not the same again.
You do if it is FWD I did a 206 recently and had to pull driveshafts and if you do that you should change the seals just to be sure.
Or you can remove the inner CV boot, disengage the spider from the diff cup and assuming the CVs aren't lubricated by the gearbox oil you can carry on without draining the oil.
Totally depends on the box.
I've done no end of clutches, got a level 3 NVQ, worked with people with lots of experience and master techs, at no point has anyone ever mentioned replacing drive shaft seals. I agree it's a good idea to change them while it's apart but I have never ever seen any get replaced with a clutch.
And personally I'd rather pull the shafts out and drain the box oil. How often does the gearbox oil really get changed on cars? I get the majority will have the original oil in there until the clutch is done. And I'd much rather pull the shaft than start messing about with CV joints.
On psa engined cars you have to take the other shaft out to get box off, you can't get away with splitting CV.
Anyway it was only suggestion didn't want to get into rights and wrongs of it all, everyone does it different, I just think it is good practice on my own vehicle to pull shafts and as Andy sais also change the box oil while you have the chance.
I love the setup on the mr2. The driveshaft is bolted to a separate stub axle at the gearbox end so removing the shaft is just a matter of unbolting it, no need to muck around with any of the greasy/oily bits.
