Absoloutely JAWDROPPING crysis map
Caporegime
18 Oct 2002
Ireland
Remember the dx9/10 jungle fight vid? Well it seems someone has made one that actually has the look (if not better) than the vid crytek showed.
I thought it was a map that was released a while back that was a good attempt at the vid map but this ones visually slaps that other out of the way.
It really needs dx10 very high to get the look of the vid though. The map is also totally crawling with enemies to fight.
Performance takes a hammering but its having it run on a pc its gobsmacking how good it looks.
Some pics (which proly dont do it justice, needs to be seen in motion)
http://homepage.ntlworld.com/gerald.marley/crysis/jung1.jpg
http://homepage.ntlworld.com/gerald.marley/crysis/jung2.jpg
http://homepage.ntlworld.com/gerald.marley/crysis/jung3.jpg
http://homepage.ntlworld.com/gerald.marley/crysis/jung4.jpg
http://homepage.ntlworld.com/gerald.marley/crysis/jung5.jpg
And the dload link:
http://www.map-factory.org/27-crysis/6-single-player/1039-gdc06-jungle
I honestly cant get over how good this looks, it really is hands down the best visuals ive seen on the pc ever.
Ive run into a bit of a bug, not sure if its just me or not, using the assault scope the view sort of freezes, but goes back to normal once i right click again.
will try it out when they release 5870 or 380 rofl
edit: made reminder on my phone for 2009 spring play crysis map rofl with new gpu
Gerard have you been using the editor to open the level like it says in the readme or did it work using console commands?
Use console commands, drop the jungle folder into the levels directory, then open the game, bring down the console and type "map jungle" hit enter and thats that :)
n/m got it working
The graphics on this map are unreal! Totally kills my system though. Will give it another try when my second GTX 280 arrives, should have been today :(
i cant use any form of scope or it 'whiteouts' and tbh its not that playable as the density of jungle is too much as is the over use of the depth of field , doesnt float my boat but thx
I think he went a bit over the top with enemies, killing a few guys at those fps is hard but they are impossible to find/see with the density of the bush.
I only had that glitch with the sniper scope
Still looks nowhere as good as the pre-release DX10 footage in the jungle.
Looks better. Are you basing that on the screens or actually playing it? Playing it and seeing it in motion blows screens away. its easily on par with the pre-release footage, imo a bit better.
I don't understand what's so great about this map?
It's just a map that's been overloaded with foliage (which anyone could do) and that has similar lighting to the GDC demo level. Yes I have played it btw. It's not really any more impressive than the other Crysis levels (that's not to say they were bad though).
