- 6 Sep 2016
If there was a room that was at absolute zero, how long would I survive? Could I open the door, rush in and out?
Well, considering that the atmosphere would be a liquid at 0K you would not be running anywhere. You'd be swimming.
Isn't absolute zero impossible to achieve?
Wouldnt it be solid at true absolute zero? Isnt the whole point of absolute zero that there is no vibration of atoms at all.
So in the room the only way to have any "space" to move would be if it was in a vacuum.
Which turns into the question of could you survive in absolute zero in space.
Which the answer would be not long at all, if you breathe out so your lungs wouldnt explode your still dealing with the water on your skin and every orifice flash boiling (eyes, mouth, ears, downstairs, itd all be burning).
Probably a few seconds wouldnt kill you but boy they would not be an enjoyable few seconds.
Looks like it depends how the atmosphere was cooled down but once it hit absolute zero it wouldn't behave like a liquid though it might be like a static liquid rather than a frozen solid I think.
In that event, the nitrogen and oxygen would boil on contact with your skin and form a gas bubble a few mm above your skin. You would survive for a while before your skin dropped to the same temperature as the surrounding liquid.
When I was at uni I put my hand in a vat of liquid nitrogen (not 0K but close at 77K) for a couple of seconds. Although extremely cold it did no damage.
if 'atomic activity pretty much stops' does that mean we are basically suspended in time.. would cells degrade at all??
if not would we be able to suspend ourselves at zero and some point forward restart if no cell degradation had taken place?
FYI i have no idea what i am going on about.
