Specs
M3A79-T Dlx latest BIOS.
Phenom 2 940
2 X 2GB's Crucial Ballistix 1066
2 X 250GB WD SATA2 hard drives.
Asus 4850 1GB graphics.
This is a bit of an epistle but here goes.
This morning my W7 disk arrived, I had built a computer, (specs above),about two months ago and tried it out first with a Linux Line CD, and no problems, then I installed W7 RC build 7100 and again no problems, I then ran it for about a week to have a good look at the new OS, then it was put back in its box waiting for OCT 22nd.
On getting home from work I loaded up the 64 bit W7 Home premium disk, it picked up the DVD asking me to press any key then it went to loading Windows files, then some wallpaper loaded and then nothing, so I tried the 32 bit version and the same thing, and as a last resort I put the RC disk in and the same again.
I then put a Linux live CD in and that loaded with no problems.
The original W7 RC install still works.
In the BIOS I set the DVD as first boot and pressed F10 to save changes and exit, I also tried the default settings and still the same.
Can anyone help as I just do not know what to do next.
Phenom 2 940
