- 25 Sep 2003
- Manchester
I have a piece of hardware from the USA, it's got two flat prongs on the charging unit and says
Input: 120VAC 60Hz 0.6A
Input Power: 33W
Output:22VDC 1.25A
As it's 120V input what can I do to convert it to 240v or will it be ok if I just bought a plug converter thing?
Or, should I just go buy a universal power supply? It uses a standard connector on the end.
Input Power: 33W
Output:22VDC 1.25A
They had a laptop power kit for £100, way too much to pay. I have a 12.5V DC multiplug, undervolting the device would damage to it right? It's a charging dock so I guess it wouldn't just charge slower it would actually damage the unit?
