AC Ryan now on OCUK !
Interesting, just a quick question but would this AC ryan fan grill:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-007-RY
be better then the Akasa grill?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-GE
looking to use them in a new build and not sure which one would restrict airflow lease while offering good protection, I've always heard great things about AC Ryan so tempted to go with theirs. Also tempted to use their 30dba/77cfm fans aswel instead of the 20dba/55cfm noctua ones I have picked out.
I think the AC Ryan one is more for looks than the best performance. They also make a range of wire guard types just like the Akasa.
PK!
lol just noticed that price myself. Surely its got to be a typo or you get a massive amount of the stuff :confused:
The website did not change my default price on that one.
Anything people after that is not on the website at the moment, quite open to suggestions providing you just name the products. :)
Same goes for any modding bits people would like to see.
other ac ryan/other modding kits would be window kits, mesh sheet, and the like. not loads of varieties but at least one of each.
price seems to of changed now hmm ;)
to the guy asking, the ac ryan filter, using one now as a replacement for my top 80mm fan is fine for use with a fan to stop dust in the case, or use to cover up an area where a fan used to be. the grill would most likely be used in conjunction with a fan and only to stop cables and the like getting caught in the fan rather than filtering.
i beg you stock a couple of the pci coolers from lian-li!
http://lian-li.com/v2/en/product/product04.php?cl_index=2&sc_index=34&ss_index=83
pref BS-03 i havent been able to find a single etailer that sells any of them within the UK!
there seems to be a few people on the forum buying a71/a70 cases recently, surely if you got a couple in they would sell.
it looks like quite a few of the lian-li cases have the holes/grill on the back for them but only a a few of the models actually ship with them inside
Great idea,definately buy one of those.If it`s easier than stocking drums of braid,how about doing the sleeving kit in black,as well as blue ect.:)
I've been looking for a Meshx 120mm black grill for ages. And now OcUK stock AC Ryan but only do the 120mm in silver. Will any black ones be added? Can't find them anywhere. :)
Also, would OcUK ever become a reseller for MMods?
What's the best way to make suggestions Yewen?
This!
I really need a BS-03 but they're in stock nowhere.
Ditto, would love some of these in!
yep, agree with everyone here, black sleeving would be a nice alternative if your going for the stealth look - espcially for mod projects as acid green or dark blue arent for everyone. ac ryan definatly do black sleeving as ive brought a kit before from a competitor, :(
that lian li pci fan thing looks great and definatly should get that in stock now, i havent read up on it yet but it looks like its could mount a 120mm rad or something. brilliant if you were at a lan party and you didnt want anyone to syphon your precious liquids-chassis alarm for the win :P
about the mountain mods thing, that looks like basically ocuk but aimed for case collecters or what have you in america, doesnt look like they will branch out to other stores. but how ace would it be if ocuk joint with another company in the US.
all i can think of is gibbo walking out from work with dollar sign sacks humming "im in the money, so much money....lalala" lol
EDIT: though heatshrink is basically permenant means of getting rid of cable ties. though i wouldnt use it instead of cable ties.
