AC Silentium T2 - a great case? Could be!
1 Jan 2006
Sheffield
I like my new Silentium T2... though when I bought it today (local store ex-display model in VGC for £45) I didn't consider the 'dead end' aspect of it as regards the non-standard PSU. However, it is for a system that will hopefully last me a year or more - I have spent far too much with my constant upgrading in the past few years! When I do upgrade, I'll sell the whole PC with the case. If the PSU fails before then, hopefully it'll be covered by a warranty of some kind. And if not... well, I'm sure I can mod something up.
It is a great case for the price - even the reasonable price that OcUK are charging. Much better than the Antec NSK4400 and the Chieftec cases I tried recently.
The suspended hard drive muffler is superb - absolutely no case vibration or rattle, and I can hardly hear my SATA WD 250gb through the thick aluminium housing. Well worth the price of admission in itself!
The cooling system really works well - I was sceptical at first as it seemed to go against the conventions of airflow and thermal dynamics, but in practise it runs very cool. I am actually quite surpised as there is no active air intake - but it runs a helluva lot cooler than the case I had before that had a 120mm fan sucking air in from the front.
To emphasize how well it works, in the system this case is housing I have a Radeon X800XL with an Arctic Cooling Silencer GPU HS&F. The Silencer is way quieter than the stock fan and handily blows the air out the back of the case, but it makes an annoying rattle at low speeds. So I have ATI Tools setup to only kickstart the fan at 25% speed if the temperature goes over 65 degrees or when a 3D game starts, increasing the speed 10% with each 5 degree temperature increase. In 2 other PC cases I used, when in 2D mode it would heat up and hover between 60 to 65 degrees centigrade, occasionally starting the rattley Silencer fan up. In the Silentium T2 it rarely goes over 43 degrees, effectively making my GPU passively cooled... until I start hammering it with Half-Life2 or Oblivion that is. Perfect!
(When gaming I tend to wear my Sennheiser headphones so as not to annoy the neighbours so am not too bothered by a little bit of fan noise... but I do like to have a quiet system at all other times.)
The output fans at the top of the case are nice and quiet but they do really shift some air. The PSU fans are a bit noisier, not dreadfully so, but enough for me to consider doing a mod and trying to whack a Fanmate into the mix.
I had no problems fitting my kit in, though I was using an m-ATX mobo so probably didn't have as much problems as others have reported using ATX standard mobos as regards front panel connectors etc... I guess it depends on the layout of your motherboard.
I've read elsewhere of other peoples complaints about the apparent flimsyness of the steel and the cheap plastic trim. Well, I'm not sure if they've changed it but I think it's fine - seems very sturdy, well put togetehr with no loose fittings, the door seems a lot more solid than other cases (eg P180!) , and I really like the way it opens to the right as I have my computer on the floor to the right of my desk.
And, contrary to what most other people say, I think it looks great! Very HAL9000. Maybe even better than the silver P180 (just maybe!), but about 2/3rds the size and weight!
The only niggle I have is with the 'tooless' design of the drive rails and PCI slots... Thanks to the lack of instructions I spent almost half an hour trying to get my DVD and floppy drives in until I realised I probably needed to take the front of the case off. And I felt the PCI holding mechanism was flimsy, difficult to use and not too effective at holding cards solid, and there seems to be no option to discard it and use screws.
Whats wrong with having to use a screw driver? You have to anyway to put your motherboard in! Grrr. I've always felt 'toolessness' was a gimmick. And in this case actually more time-consuming and difficult than digging out yer Philips!
Overall, a great case with great cooling and one I would recommend for a quick quiet fix ... maybe just a little bit noisier than I would like but I think with a bit of tinkering of the PSU fans it will be perfect for me for the next year or so.
Yeah, i'm using one right now, and i love it.It'a nice solid case, and it's really quiet too, which is what i wanted when i was looking for a case a year ago.The tool-less design didn't bother me, infact i found it took me less time to assemble my system in it.
The PSU isn't non-standard - it's a Seasonic mATX/SFX, and you can buy them off the shelf from a competitor. You can get them upto 450W iirc.
The only thing about the HDD mounting is that the rubber bands tend to perish.
In 6 months/a year - The HDD will fall off if case is moved.
In terms of build quality, cooling etc - It's a top case. :)
Only 1 HDD rack, but very quiet and nicely designed.
BTW - It's a Seasonic PSU so unlikely it will die and it should power everything you need it to. :)
Hmmmm.... maybe I spoke too soon.
The PSU fans have started randomly speeding up and slowing down. I don't mean every five minutes after doing stuff, I mean every ten seconds or so the pitch and hum of 'em changes. Up and down, up and down. This constant pitch change is far worse than if they were at full pelt all the time.
It actually started after I had a go at disconnecting the fans from the PSU and connecting them to the mobo chassis fan header via a fan mate. I onl;y had them on that for a few mins before I realised that even at the lowest setting they weren't actuallly any slower/quieter than when connected to the PSU. So I put them back on the PSU as before.
What have I done wrong? Wish I left 'em alone.
i am about to buy a new case for my pc , would this one be ok then ? its for a conroe set up and with a zalman fatal1ty cooler? do i need to add extra fans to the case or is stock fans with it enough for overclockeing?
It's very difficult to say, I wouldn't have thought that the fanmate could do them any damage as running the fans below a certain voltage should just stop them. I didn't think you could damage fans like that.
No - where would be the fun in that?
The case will be fine. I'd give that cooler a bodyswerve though. AC Freezer 7 Pro is fantastic value and will cool all you require (although they've slipped the price up a bit of late).
thanks , is there any reason for not getting the zalman? pc format said it was the best cooler they tested?
I just tried stopping the PSU fans and it seems the CPU fan is also rising and falling in pitch i.e. speeding up and slowing down, randomly. Do you think this suggests a varying in power usage/drain, or that my PSU is being weird and varying it's output, or something else?
It happens even if I'm not doing anything and have no windows open etc.
Magazine reviews are notorious for being inconsistent. There is nothing wrong with the Zalman, but there are much better coolers from Scythe, Thermaltake (Typhoon) and AC.
I would go fro a Sythe cooler personally, or a big Typhoon by Thermaltake.
Not used a lot of the coolers better than those two, may be best of making a thread in overclocking and cooling. :)
Of course they do. People asked for them, so they got them in. For Thermaltake - look under CPU coolers - Thermaltake, for Scythe - look under CPU coolers - other. I'd still buy the AC Freezer 7 Pro though.
