I own an AVT150 and am a bit dissapointed with it so I went into Sound Control with about £600 to spend on a nice new amp
I tried
a Hot Rod Delluxe (they said they would order me the 2X12 Deville in)
a TSL 601
and an AC30 CC2
the Hot Rod Delluxe had a brilliant clean tone and a brilliant dirty tone but I wasn't sure on the high gain, not to say I didn't like it but still
I tried the TSL and just wasn't impressed after trying the Fender. So I'll probably not get this one.
I tried the Vox just just because I happened to spot it and liked both the clean and dirty a lot, but there wasn't a lot of gain, but I'm sure if I put a TS9 infront of it then it would have. I did really like it though.
So... the question is which amp would you go for and why. You can base it completely on your own experiences or use my opinions to help me decide!!
I'm going to go back down again to try them again before I buy
Also any other amp suggestions would be good.
Thanks in advance.
I tried
a TSL 601
and an AC30 CC2
Thanks in advance.
