When playing video files on my pc I use WMP classic along with AC3Filter for sound. I have got everything configured correctly apart from one annoying and major problem.
The problem is that I can hear all the background sounds and all that fine however the main speech is either extremley quiet and basically non existent. However when I switch it to stereo/ Prologic II the main speech is fine but then I dont get the benfit of surround sound.
If it helps the PC is connected to my AV reciever via optical.
Thanks
Thanks
