AC7Pro v. Tuniq Tower
3 Sep 2006
London
Hi. I'm running with an AC7Pro at the moment, but am seriously considering upgrading to the Tuniq Tower in order to gain another few degrees of cooling. I have an x6800 on an Abit AW9D-Max, the AC7Pro fits just fine, but I was wondering if anyone else is running this cooler/mobo combination and how its working for you. Thanks.
You will certainly get an improvement in cooling, which for double the price you should do!
It will be in the order of 3-5C under load. At idle I very much doubt that there will be much difference between the two coolers. The Tuniq might be a big less noisy as you should be able to almost turn it off.
After testing several, I'm now using the Thermalright HR-01 S775 edition with the 120mm tunnel. This is a completely passive cooler that has a flexible ventilation duct that fits onto the rear 120mm fan (your case has to have a 120mm rear fan for this to work) and it runs as cool as the AC Freezer 7 Pro but it is a lot quieter. I like it a lot. It is almost as expensive as the Tuniq though.
