Accelero+8800Gt
31 Oct 2007
Gods County(Allegedly)
Am awaiting delivery of Accelero S1 to cool my Zotac 8800gt (not AMP) .
Anyone tried the combo? and if so with what results?
Any hints/tips much appreciated.
Thanks in advance:D
Idles at 30-36c, loads at about 42c.
Raikiri , The fan you have attached is a ?
Am currently running at 50c idle 80c load (crysis) - that looks a nice improvement.
Easy fit ? Any probs in removing existing Zotac cooler?
It isn't a Zotac, uses much the same cooler though. Undo all the screws and it just lifts off no problem.
The fan is a Yate Loon 120mm running at 7v (~800rpm).
I accidentally bought the S2 instead of the S1 (how I managed that I'm not quite sure).
I'd got half way through installing it before I realised and went ahead with it anyway. I now have 45-50C idle and 60-75C load (OC'd to spec in sig) depending on the game without an extra fan attached to it, and the S1 is a lot better than the S2, so if mine's anything to go by then it's definitely worth buying :)
Fitted today included turbo fans .
Idle now 36c (13c drop)
Load now 47c (30c+ :cool:drop)
Running at stock speeds for Zotac i.e.660core/1600shaders/1800mem.
Decided I will let it settle for a week and then push it a bit:D
Took my time cleaned the gpu/ram/vreg twice with Akasa Tim clean and then with isopropyl alcohol befor fixing ram heatsinks and (I had some old coolermaster alum.ones- bought years ago but never used) vreg heatsinks.
All fitted and appears that sinks have stuck - hopefully they will stay stuck
Only problem I had was the packet contained 2 extra screws and washers but no female T fixing bits. - just didn't bother with the plastic fittings which I think are to give it support and rigidity but as quite light and rigid without am not too worried
First time swap gpu cooler for me - went quite smoothly; took about 3hrs in total including tea brake .
This has my unreserved recomendation - the temp drop and lack of noise is well worth the expenditure and time spent:)
