I have the Twin turbo 3 and have tested two of these and both have the same results, annoyingly.
When the fans get up to around 47% speed using MSI or GPU tweak there is a distinct noise coming from the fans, I am pretty sure it's normal and it's just the noise the blades generate but annoyingly it's around the mark where the fans usually tend to be operating at that RPM which is about 47% ish speed.
I have had to set the fan curve to skip straight up from 40% speed to 50% speed so it hangs around one or the other rather than in between where this noise is at it's most annoyance.
Side note. Obviously these speeds are not in tandem with the real RPM, I think 60% speed reading in MSI is 100% actual fan speed.
