Last year I completed a build of my new gaming PC, which uses parts almost exclusively purchased from OcUK.
Some not-very-good photos and specification here:-
https://www.overclock.net/threads/o...icture-gallery.584302/page-5524#post-28637655
I've recently had a chance to put a bit of effort in to using the AquaComputer 6XT fan/pump controller to tune the machine for noise. Firstly, it's the most amazing piece of technology: if you're planning a water-cooled machine I can't recommend it highly enough.
Secondly, I've now managed to lower fan noise to the point where the loudest thing in my machine - by *far* is the 2000W Leadex SuperFlower PSU. Even with one GPU completely idle [non-SLI mode] and everything idling along at 0%, the machine is noisy... And that's with just the 4 fans on the CPU radiator spinning at ~250-350rpm [and they're Nuctua NFP-14 PWMs, which are rated at about 19dBA.
So first question would be - would you expect the PSU to be the noisiest thing in the case at idle? I have a TackLife sound level meter, so ran some tests... from a distance of 1 metre and 60cm off the floor, on a tripod, the sound steps up from an ambient of 30dBA to 38dBA when the machine starts up.
38 is pretty audible in a quiet room, although not so obvious when gaming.
Second question would be: how would you recommend I consider tackling this? The case I'm using (Thermaltake WP200) has space for 4 PSU's, although I'd only want to think about fitting 2. I could, for example, fit a pair of PSU's and then strap them, which I understand is possible [I've seen Singularity Computers do that on their YouTube channel].
Very keen to ask what approaches others have tried to secure a silent or super-quiet PSU. I can't fault this SuperFlower for quality of delivery, but it does blow a bit, so if I could sort that I'd be very happy...
Thanks in advance.
Thanks in advance.
