Hi everyone hope someone can point me in the right direction with this as it has taken up the whole of last week and i cant get it working.
I have VMWare Workstation installed with a linux vm running on it. i use it as a test Apache webserver.
The virtual machine is setup with a bridged connection via my physical NIC with a static ip address.
Ive created a NO-IP account to give it a permanent name as I dont have a static external ip address on my router. so here is the setup
VM with a static IP and Bridget Connection with NO-IP configured
Physical PC hosting the VM
Virgin Media Router
If i ping the url assigned to my IP it works fine and shows that its pinging my external ip address but cannot make it point to the apache webserver.
i tried forwarding a specific port from the router to the vm but that doesnt work.
is it apache or the vm? stuck....
any help would be much appreciated thanks
Virgin Media Router
		 ). try and give the VM a static ip address or reserve one in the DHCP scope (most home routers use DHCP by default)
