Hi,
Basically I have an Access 2007 database which has attachments in it. All is fine and dandy and it works fine. However it's nearing the 2GB limit. I have built a Windows 2008 / SQL 2008 server in the hope I could import it into this. SQL though only seems to want to import Access 2003 files. I can't convert it to 2003 because of the attachment requirement.
Does anyone have any idea how to do this or another database program that allows for more then 2GB and accepts attachements? As said providing the SQL backend, if needed, is no problem.
M.
M.
