Access point & switch combined
26 Jul 2017
Evening all, need a switch for 3 hard wired devices and wifi aswell for the wireless devices
Already a bt router on site, so this will run off that in the building next door hard wired ofcourse
Should I be looking at routers and just turn off and change settings as per 1 of the stickys above or another newer solution?
Thanks for any help
You can put almost any wireless router into AP mode. Some will have a mode you can select through the GUI which will make life easier.
No particular brands in mind. How much are you willing to spend and how exotic do you expect the wireless to be?
