Access point with built in hub?
Caporegime
18 Oct 2002
Lake District
Looking for something that will take WAN, has wireless (5ghz is optional) and has at least 3 switch ports available to use.
Currently using a Buffalo 'something' but the wireless has gone flakey on it.
Any suggestions?
Well the current configuration is that one of the LAN ports from the BT hub go into a Powerline adapter, then at the other end of the house it comes out into the Buffalo.
So I'm not sure if I require WAN or not, its set to bridged at the moment.
You require an access point with LAN ports.
