Hello,
Networking question:
I have CAT 6 ethernet cable run into every room in my UK house.
I have a mesh network running which is Wi-Fi 6 (Deco X20 - well reviewed users). 50% (3 of them) are working over ethernet backhaul.
However, I am struggling with large drop offs in Wi-fi speeds. Down from 150mb over the Ethernet plugged in devices to 25mb Wi-Fi devices nearly always. I think some of this is down to the solid walls we have in our house. We don't have stud walls anywhere. I have a Starlink router running (bypass mode) into the mesh network which acts as the router. Fast roaming turned on and 2.4 and 5 channels both active on auto.
I am thinking about swapping out the mesh network for a few access points instead. The access points will be run solely off the ethernet over POE and will allow roaming like a mesh network. My theory being that the mesh network is simply amplifying an already poor signal where as a access point will emits it own strong signal. However, that theory falls over because of the mesh network ethernet backhaul unless I am wrong?
Secondly, the access points will run over POE. However, a lot of my devices plugged in are not POE items...TVS, PlayStation etc. Am I right in thinking the ethernet switch will be POE but the items won't receive power unless they call for it? Providing the POE switch is not a passive one. I don't want to fry items. My current switch is not POE but I was thinking about either by an injector or just a new POE switch. Again thoughts needed!
I am not an network engineer but just a slightly tech interest finance person keen on better Wi-Fi speeds.
Teach me please!
Also, to provide answers for those interested. I use Starlink because we don't have fibre and mobile broadband is terrible across the networks in my location; it is my only option. The Starlink router generation 3 cannot reach across my house so I need a larger Wi-Fi network either via a mesh network or access point.
Teach me please!
