Access RAW partition.
10 Jan 2004
Poland
I have a spare HD with two partitions on it, one is accessible, the other isnt and it's file system is listed as RAW, is there any program(free hopefully) that can either fix the partition or make it accessible so i can save the files on it?
Thanks guys.
RAW indicates that the partition table data for that partition is damaged/missing and so the computer doesn't know what filesystem it is. RAW means "no file system" as far as the system can tell :)
If you know what filesystem it is, then you might be able to manually mount it with linux using the mount command.
