Accessing iso files over a network
6 Nov 2005
MK45
I have a few (large - 7+ Gb) iso files that I need to access over a netork. Normally, I use a virtual CD Rom app supplied by Microsoft to do this, but it fails to load the files over a network. Can anyone suggest a different app that will be able to stream these over a 54 Mbps wireless network so that I can read them? I know that there is no problem streaming these files over the network, as they can be accessed on my MacBook Pro - it's just the Windows app that falls over :(.
Many thanks :)
I've used poweriso in the past and it's worked for me.
Just share the virtual drive and then mount the image....you should be able to access it through the network
I was trying to get the file to mount on the computer I'm using, rather than sharing a virtual drive on the host PC. There are quite a few files, so I don't particularly want to be having loads of virtual drives on the host PC.
Anyway, PowerISO is able to mount the shared files on the PC I'm using, so that's all I wanted.
