Accessing my other hard drive through ubuntu?
7 Mar 2005
Arkham
I have two hard drives, C: and D:
Just formatted my C: drive and installed Ubuntu because my xp installation was borked.
All seems well and good, but all my music and files etc are on my D: drive, and I can't for the love of god, get to my stuff.
From the small bit of linux i've figured out in the past ten minutes i'd guess i should be looking at /dev/hda or /dev/hdb etc but it won't let me access them.
Please someone tell me I haven't lost access to all my stuff!!
Thanks in advance,
Sean
e: colour VGA+ 80x25
[ 20.336054] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 20.342875] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 20.384125] Memory: 1987112k/2096832k available (1620k kernel code, 108708k reserved, 997k data, 136k init)
[ 20.384164] Calibrating delay loop... 4718.59 BogoMIPS (lpj=2359296)
[ 20.409842] Security Framework v1.0.0 initialized
[ 20.409847] SELinux: Disabled at boot.
[ 20.409855] Mount-cache hash table entries: 256
[ 20.409916] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 20.409919] CPU: L2 Cache: 1024K (64 bytes/line)
[ 20.409923] CPU: AMD Athlon(tm) 64 Processor 4000+ stepping 0a
[ 20.410011] checking if image is initramfs... it is
[ 20.694229] ACPI: Looking for DSDT in initrd... not found!
[ 20.758650] not found!
[ 20.785338] Using local APIC timer interrupts.
[ 20.826942] Detected 12.516 MHz APIC timer.
[ 20.826955] testing NMI watchdog ... OK.
[ 20.836933] NET: Registered protocol family 16
[ 20.836950] ACPI: bus type pci registered
[ 20.836955] PCI: Using configuration type 1
[ 20.836958] mtrr: v2.0 (20020519)
[ 20.837229] ACPI: Subsystem revision 20050729
[ 20.842690] ACPI: Interpreter enabled
[ 20.842692] ACPI: Using IOAPIC for interrupt routing
[ 20.843521] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 20.843523] PCI: Probing PCI hardware (bus 00)
[ 20.843538] ACPI: Assume root bridge [\_SB_.PCI0] segment is 0
[ 20.846400] Boot video device is 0000:01:00.0
[ 20.855521] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 20.860795] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 *11 14 15)
[ 20.860977] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 *10 11 14 15)
[ 20.861156] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 10 11 14 15)
[ 20.861335] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *10 11 14 15)
[ 20.861516] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
[ 20.861708] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
[ 20.861888] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
[ 20.862069] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 14 15) *0, disabled.
[ 20.862151] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 20.862158] pnp: PnP ACPI init
[ 20.865922] pnp: PnP ACPI: found 12 devices
[ 20.865973] usbcore: registered new driver usbfs
[ 20.865986] usbcore: registered new driver hub
[ 20.866012] PCI: Using ACPI for IRQ routing
[ 20.866014] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[ 20.866086] agpgart: Detected AGP bridge 0
[ 20.866754] agpgart: Aperture conflicts with PCI mapping.
[ 20.866770] agpgart: Aperture from AGP @ e6000000 size 32 MB
[ 20.868474] agpgart: AGP aperture is 32M @ 0xe6000000
[ 20.868487] PCI-DMA: Disabling IOMMU.
[ 20.869141] pnp: 00:06: ioport range 0x680-0x6ff has been reserved
[ 20.869144] pnp: 00:06: ioport range 0x290-0x297 has been reserved
[ 20.869359] IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $
[ 20.869507] audit: initializing netlink socket (disabled)
[ 20.869514] audit: initialized
[ 20.869591] VFS: Disk quotas dquot_6.5.1
[ 20.869603] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 20.869635] devfs: 2004-01-31 Richard Gooch ([email protected])
[ 20.869639] devfs: boot_options: 0x0
[ 20.869659] Initializing Cryptographic API
[ 20.881147] Linux agpgart interface v0.101 (c) Dave Jones
[ 20.881219] PNP: No PS/2 controller found. Probing ports directly.
[ 20.881390] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 20.881401] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 20.881405] Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
[ 20.881502] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 20.881599] ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 20.882789] ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 20.882887] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 20.882939] io scheduler noop registered
[ 20.882949] io scheduler anticipatory registered
[ 20.882954] io scheduler deadline registered
[ 20.882959] io scheduler cfq registered
[ 20.883175] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 20.883226] NET: Registered protocol family 2
[ 20.892650] IP: routing cache hash table of 16384 buckets, 128Kbytes
[ 20.892904] TCP established hash table entries: 524288 (order: 10, 4194304 bytes)
[ 20.897016] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 20.897523] TCP: Hash tables configured (established 524288 bind 65536)
[ 20.897590] NET: Registered protocol family 8
[ 20.897592] NET: Registered protocol family 20
[ 20.897727] ACPI wakeup devices:
[ 20.897729] PCI0 UAR2 UAR1 AC97 USB1 USB2 USB3 USB4 EHCI PWRB SLPB
[ 20.897739] ACPI: (supports S0 S1 S3 S4 S5)
[ 20.897896] Freeing unused kernel memory: 136k freed
[ 20.908284] vga16fb: initializing
[ 20.908287] vga16fb: mapped to 0xffff8100000a0000
[ 20.975095] Console: switching to colour frame buffer device 80x30
[ 20.975099] fb0: VGA16 VGA frame buffer device
[ 22.071345] Capability LSM initialized
[ 22.077408] NET: Registered protocol family 1
[ 22.087065] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 22.087088] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 22.087091] ACPI: bus type ide registered
[ 22.092711] VP_IDE: IDE controller at PCI slot 0000:00:0f.1
[ 22.092730] ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 20
[ 22.092740] PCI: Via IRQ fixup for 0000:00:0f.1, from 255 to 4
[ 22.092765] VP_IDE: chipset revision 6
[ 22.092766] VP_IDE: not 100% native mode: will probe irqs later
[ 22.092776] VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
[ 22.092785] ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:DMA
[ 22.092795] ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
[ 22.092802] Probing IDE interface ide0...
[ 22.476003] hda: Maxtor 6Y120P0, ATA DISK drive
[ 22.730891] hdb: ST340810A, ATA DISK drive
[ 22.787700] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 22.787776] Probing IDE interface ide1...
[ 23.578519] hdc: _NEC DVD_RW ND-3520AW, ATAPI CD/DVD-ROM drive
[ 24.190311] ide1 at 0x170-0x177,0x376 on irq 15
[ 24.190383] Probing IDE interface ide2...
[ 24.702936] Probing IDE interface ide3...
[ 25.214712] Probing IDE interface ide4...
[ 25.726487] Probing IDE interface ide5...
[ 26.240580] hda: max request size: 128KiB
[ 26.241139] hda: 240121728 sectors (122942 MB) w/7936KiB Cache, CHS=65535/16/63, UDMA(133)
[ 26.241269] hda: cache flushes supported
[ 26.241316] /dev/ide/host0/bus0/target0/lun0: p1
[ 26.250732] hdb: max request size: 128KiB
[ 26.251779] hdb: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
[ 26.251783] hdb: cache flushes not supported
[ 26.251808] /dev/ide/host0/bus0/target1/lun0: p1 p2 < p5 >
[ 26.301625] hdc: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
[ 26.301630] Uniform CD-ROM driver Revision: 3.20
[ 26.482641] Attempting manual resume
[ 26.482823] swsusp: Suspend partition has wrong signature?
[ 26.510495] ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 26.510538] skge addr 0xfb800000 irq 17 chip Yukon-Lite rev 9
[ 26.510608] skge eth0: addr 00:11:d8:82:c4:dc
[ 26.524887] SCSI subsystem initialized
[ 26.525722] libata version 1.11 loaded.
[ 26.526612] sata_via version 1.1
[ 26.526625] ACPI: PCI Interrupt 0000:00:0f.0 -> GSI 20 (level, low) -> IRQ 20
[ 26.526630] PCI: Via IRQ fixup for 0000:00:0f.0, from 10 to 4
[ 26.526657] sata_via(0000:00:0f.0): routed to hard irq line 4
[ 26.526690] ata1: SATA max UDMA/133 cmd 0xC400 ctl 0xC002 bmdma 0xB000 irq 20
[ 26.526706] ata2: SATA max UDMA/133 cmd 0xB800 ctl 0xB402 bmdma 0xB008 irq 20
[ 26.727050] ata1: no device found (phy stat 00000000)
[ 26.727053] scsi0 : sata_via
[ 26.927962] ata2: no device found (phy stat 00000000)
[ 26.927963] scsi1 : sata_via
[ 26.935766] USB Universal Host Controller Interface driver v2.2
[ 26.935813] ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 21
[ 26.935824] PCI: Via IRQ fixup for 0000:00:10.0, from 11 to 5
[ 26.935848] uhci_hcd 0000:00:10.0: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
[ 26.997070] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
[ 26.997082] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000c800
[ 26.997180] hub 1-0:1.0: USB hub found
[ 26.997186] hub 1-0:1.0: 2 ports detected
[ 26.999942] ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 21
[ 26.999945] PCI: Via IRQ fixup for 0000:00:10.1, from 11 to 5
[ 26.999965] uhci_hcd 0000:00:10.1: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#2)
[ 27.061919] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
[ 27.061923] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000d000
[ 27.061993] hub 2-0:1.0: USB hub found
[ 27.061999] hub 2-0:1.0: 2 ports detected
[ 27.064910] ACPI: PCI Interrupt 0000:00:10.2 -> GSI 21 (level, low) -> IRQ 21
[ 27.064913] PCI: Via IRQ fixup for 0000:00:10.2, from 10 to 5
[ 27.064933] uhci_hcd 0000:00:10.2: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#3)
[ 27.126894] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
[ 27.126897] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d400
[ 27.126969] hub 3-0:1.0: USB hub found
[ 27.126974] hub 3-0:1.0: 2 ports detected
[ 27.129884] ACPI: PCI Interrupt 0000:00:10.3 -> GSI 21 (level, low) -> IRQ 21
[ 27.129888] PCI: Via IRQ fixup for 0000:00:10.3, from 10 to 5
[ 27.129908] uhci_hcd 0000:00:10.3: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (#4)
[ 27.191865] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
[ 27.191869] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000d800
[ 27.191939] hub 4-0:1.0: USB hub found
[ 27.191944] hub 4-0:1.0: 2 ports detected
[ 27.207916] ACPI: PCI Interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 21
[ 27.207934] ehci_hcd 0000:00:10.4: VIA Technologies, Inc. USB 2.0
[ 27.207970] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
[ 27.207977] ehci_hcd 0000:00:10.4: irq 21, io mem 0xfbc00000
[ 27.208007] ehci_hcd 0000:00:10.4: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
[ 27.208062] hub 5-0:1.0: USB hub found
[ 27.208068] hub 5-0:1.0: 8 ports detected
[ 28.333345] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 28.620219] usb 2-2: new low speed USB device using uhci_hcd and address 3
[ 29.259529] usbcore: registered new driver hiddev
[ 29.281976] input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:10.1-1
[ 29.338952] input: USB HID v1.11 Keyboard [Chicony USB Gaming Keyboard Pro] on usb-0000:00:10.1-2
[ 29.442917] input,hiddev96: USB HID v1.11 Device [Chicony USB Gaming Keyboard Pro] on usb-0000:00:10.1-2
[ 29.498867] input: USB HID v1.11 Gamepad [Chicony USB Gaming Keyboard Pro] on usb-0000:00:10.1-2
[ 29.498873] usbcore: registered new driver usbhid
[ 29.498874] drivers/usb/input/hid-core.c: v2.01:USB HID core driver
[ 29.784670] ACPI: CPU0 (power states: C1[C1])
[ 29.945337] Attempting manual resume
[ 29.945501] swsusp: Suspend partition has wrong signature?
[ 29.953489] kjournald starting. Commit interval 5 seconds
[ 29.953500] EXT3-fs: mounted filesystem with ordered data mode.
[ 31.407657] md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
[ 33.765366] Adding 1614492k swap on /dev/hdb5. Priority:-1 extents:1
[ 34.017772] EXT3 FS on hdb1, internal journal
[ 41.249419] parport: PnPBIOS parport detected.
[ 41.249458] parport0: PC-style at 0x378, irq 7 [PCSPP]
[ 41.333916] lp0: using parport0 (interrupt-driven).
[ 41.352847] mice: PS/2 mouse device common for all mice
[ 41.376812] Real Time Clock Driver v1.12
[ 41.408952] ieee1394: Initialized config rom entry `ip1394'
[ 41.412270] sbp2: $Rev: 1219 $ Ben Collins <[email protected]>
[ 44.713174] device-mapper: 4.4.0-ioctl (2005-01-12) initialised: [email protected]
[ 46.176467] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 46.185261] shpchp: shpc_init : shpc_cap_offset == 0
[ 46.185271] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 46.239437] ohci1394: $Rev: 1250 $ Ben Collins <[email protected]>
[ 46.239456] ACPI: PCI Interrupt 0000:00:07.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 46.239466] PCI: Via IRQ fixup for 0000:00:07.0, from 11 to 0
[ 46.294820] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[16] MMIO=[fb600000-fb6007ff] Max Packet=[2048]
[ 46.299826] ACPI: PCI Interrupt 0000:00:0e.2 -> GSI 16 (level, low) -> IRQ 16
[ 46.352264] ohci1394: fw-host1: OHCI-1394 1.1 (PCI): IRQ=[16] MMIO=[fba00000-fba007ff] Max Packet=[2048]
[ 46.541890] ACPI: PCI Interrupt 0000:00:0e.0[A] -> GSI 19 (level, low) -> IRQ 19
[ 46.544303] Installing spdif_bug patch: Audigy 2 ZS [SB0350]
[ 47.053594] gameport: EMU10K1 is pci0000:00:0e.1/gameport0, io 0xa400, speed 1150kHz
[ 47.558260] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0011d800000d253e]
[ 47.816180] ieee1394: Host added: ID:BUS[1-00:1023] GUID[00023c01510a4d91]
[ 49.038881] input: PC Speaker
[ 49.071311] Floppy drive(s): fd0 is 1.44M
[ 49.098519] FDC 0 is a post-1991 82077
[ 49.279023] ts: Compaq touchscreen protocol output
[ 49.951954] skge eth0: enabling interface
[ 49.961953] NET: Registered protocol family 17
[ 51.638332] skge eth0: Link is up at 100 Mbps, full duplex, flow control tx and rx
[ 59.851137] NET: Registered protocol family 10
[ 59.851223] Disabled Privacy Extensions on device ffffffff8035a5a0(lo)
[ 59.851342] IPv6 over IPv4 tunneling driver
[ 60.566088] ACPI: Power Button (FF) [PWRF]
[ 60.566110] ACPI: Power Button (CM) [PWRB]
[ 60.566118] ACPI: Sleep Button (CM) [SLPB]
[ 60.624709] ibm_acpi: ec object not found
[ 69.900113] eth0: no IPv6 routers present
[ 487.595080] Bluetooth: Core ver 2.7
[ 487.595088] NET: Registered protocol family 31
[ 487.595090] Bluetooth: HCI device and connection manager initialized
[ 487.595103] Bluetooth: HCI socket layer initialized
[ 487.603725] Bluetooth: L2CAP ver 2.7
[ 487.603729] Bluetooth: L2CAP socket layer initialized
[ 487.611439] Bluetooth: RFCOMM ver 1.5
[ 487.611448] Bluetooth: RFCOMM socket layer initialized
[ 487.611461] Bluetooth: RFCOMM TTY layer initialized
[ 524.771430] powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.40.4)
[ 524.774769] powernow-k8: 0 : fid 0x2 (1000 MHz), vid 0x12 (1100 mV)
[ 524.774773] powernow-k8: 1 : fid 0xa (1800 MHz), vid 0xe (1200 mV)
[ 524.774776] powernow-k8: 2 : fid 0xc (2000 MHz), vid 0xa (1300 mV)
[ 524.774779] powernow-k8: 3 : fid 0xe (2200 MHz), vid 0x6 (1400 mV)
[ 524.774782] powernow-k8: 4 : fid 0x10 (2400 MHz), vid 0x2 (1500 mV)
[ 524.775118] cpu_init done, current fid 0x10, vid 0x0
[ 524.785774] powernow-k8: ph2 null fid transition 0x10
[ 538.540430] ibm_acpi: ec object not found
[ 692.528970] ppdev: user-space parallel port driver
[ 692.529475] ppdev0: registered pardevice
[ 692.566812] ppdev0: unregistered pardevice
[ 692.566933] ppdev1: claim the port first
[ 692.567011] ppdev2: claim the port first
[ 871.815061] ibm_acpi: ec object not found
[ 875.365242] cdrom: open failed.
without looking cos i'm off out in 2 mins:
sudo mkdir /mnt/someappropriatename
sudo mount /dev/hdb1 (or try increasing numbers) /mnt/someappropriatename
I'd just like to be able to run a couple of native windows proggies, things like the proper msn messenger for example?
I'm incredibly new to this whole thing - I'm going to need to find a copy of xp anyway soon to play my games but will probably stick with ubuntu for everything else..
DailyGeek said:
You, my man, are a star!
Now how the hell do I get WINE working? :p
Well, first you need to find a goat to sacrifice...
Seriously, it's a challenge. Transgaming is a good start, or Crossover Office.
