Accidently deleted call of duty 4 profile...help?
28 Jul 2007
So as title really. A few hours ago i accidently deleted my call of duty 4 profile within the game. Does anyone know if there isd anyway to restore it?
Tried google with no luck.
Thanks.
You could check the profiles folder on the off chance its still there but been disabled.. but im guessing its toast. Hope your favourite setup wasn't too high level ^_^
System restore sorted mine out when one of the patches did funny things ..if not...hey, think how much more enjoyment you have ahead of you, like the first time you unlock the first Golden weapon !!
I tried system restore with no luck.
Got a data recovory program. Anyone know the file extension i should be searcing for. Also if it does find it, any ideas on what the file will be called.
Cheers
Cheers
it'll likely be a folder, if not just go into your profiles folder atm in program files and see the extensions.
yeah gave that a try. went in to my call of duty 4 folder. and there is no folder in there for profiles, dipite having another profile in the game still working. Ive tried showing hidden files and folders still with no luck. Strange. Any suggestions?
P.s this is vista 64
Cheers
yeah that is true. I dont have much time for games though, maybe 1 hour max a couple nights a week, so takes me quite a long time.
Is there any chance you might be able to take a look at the file extension if you have the game?
If all else fails get the unlock for all weps, at least then you have a fighting chance in MP and you can work through the challenges.
