I recently started running longer distances and since I tend to run in a forested park with lots of small loops and trails it is near impossible to estimate distances purely through a map. I have a fitbit one and have been using the Android fitbit app's GPS tracker which seems reasonably accurate from some tests I made but the trouble I find is the app crashes a lot, e.g, 1 in 3 runs it will crash before saving the track, which is a a sperate issue I will post about.
Anyway, that made me install endomondo app, which I really like the interface and flexibility. It also doesn't crash which is great.
However, endomondo consistently under reads the distance. E.g. The fitbit app today said 10.0 miles, endomondo 9.1. Last week the fitbit read 13.2, endomondo 11.9.
Looking at the GPS tracks it is clear that endomondo samples the GPS at a lower temporal resolution. My runs go through fairly curvy and twisty forest paths and the larger distances between GPS points misses a lot of the detail. For runs that go along fairly straight streets or gentle curves it works ok but not for my typical runs. There is a lake that is makes as 0.5 miles around which fitbit agrees with (0.49 on average) but endomondo is nearer 0.42m. I'll do quite a few loops around the lake because it is flat,wide path and pretty. Not particularly twisty but even there you can see the straighter lines of endomondo's track vs fitbit.
Anyone experienced similar issues? Any recommendations for alternative apps?
