- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys and gals!
Some nice prices here which will expire on Saturday at 4pm.
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £89.99 inc VAT
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*. (*Requires the Corsair Link Commander, sold separately). The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool blue LED display lets you know at a glance which profile is being used.
- Dual length 240mm radiator for increased surface area and cooling potential.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiation Dimensions: 120mm x 275mm x 27mm
- Fan Dimensions: 120mm x 25mm
- Air Flow per Fan: 46 - 92 CFM
- Combined Fans Noise Level: 25 - 42 dBA
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Zalman CNPS10X Flex CPU Cooler (Socket 754/939/AM2/AM2+/AM3/775/1155/1156/1366) @ £22.98 inc VAT
Introducing Zalman's third and final cooler to sport the CNPS10X moniker, the CNPS10X FLEX. The FLEX (or flexible) version is supplied without fans. This gives you the flexibility to use any 120mm fan(s) you see fit.
Also with the FLEX it is possible to install up to two 120mm fans unlike the EXTREME and QUIET versions which only can accommodate a single 120mm fan, giving you the potential to have either an extremely quiet CPU cooling solution or one that provides powerful cooling.
- Socket Compatible: 939 / AM2 / AM3 / 775 / 1155 / 1156 / 1366
- Dimensions: 133 x 74 x 151mm
- 5 U shaped heatpipes.
- Weight: 700g
- Material: Aluminium Fins / Copper Base
Was £28.99 Inc. VAT
Only £22.98 inc VAT.
ORDER NOW
Cooler Master Elite 335 Case - Black @ £26.99 inc VAT
The Elite 335 is a mid-tower computer case from Cooler Master. The Elite 335 is made of 1.0mm steel and supports ATX and Micro-ATX motherboards. There are 4 5.25" drive bays available, as well as 6 internal and 1 external 3.5" drive bays. 7 expansion PCI slots are available as well. The cooling system utilizes a front-intake and rear-exhaust fan setup. The front intake fan also uses a washable air filter. The Elite 335 supports a standard ATX-PSII power supply.
- 4x 5.25" Drive Bays
- 5x HDD bays
- 1x FDD bays
- Tool-Free mechanical design for quick assembly and maintenance
- Meshed front panel design provides the superior airflow and maximum cooling performance
- Built-in washable front air filter
- 120mm fan in the front and rear to give your PC the best ventilation while maintain silent cooling solution (front fan not included, rear fan is included)
- Solid construction makes the chassis durable and sturdy
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Corsair Graphite 600T Midi Tower Case - Black @ £119.98 inc VAT
nonl2brThe Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.<br><br>
- Twin 200mm cooling fans with white LEDs for excellent cooling<br>
- Eight expansion slots provides you flexibility for multiple graphics card solutions<br>
- Unique cable routing holes guarantees you a clean and clutter-free installation<br>
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance<br>
- Motherboard compatibility: ATX and MicroATX<br>
- Front I/O Ports: USB2.0 x 4, USB3.0 x 1, FireWire x 1, Audio x 2<br>
- Cooling: 2 x 200mm white LED fans <br>
- Tool-free optical drive installation makes building your system faster than ever<br>
- CPU backplate cutout makes upgrading your CPU heatsink easy<br>
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!<br>
- Two year warranty with Corsair’s world-class customer service and technical support<br>
<center>
<span id="ctl00_ctl00_cpBodyCode_cpSubBodyCode_lblHTML"><object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/L_XuntEjQS8&hl=en_GB&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object></span>
</center>
Was £129.99 Inc. VAT
Only £119.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £190.99 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Was £209.99 Inc. VAT
Only £190.99 inc VAT.
ORDER NOW
OCZ ZS Series 750W '80 Plus Bronze' Power Supply @ £69.98 inc VAT
The OCZ ZS Series PSU is the superlative solution for driving today's value oriented gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Enthusiast-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the OCZ ZS Series PSU was engi-neered to be the quietest PSU available in its class, elimi-nating distracting noises from your PC. Highly efficient, featuring up to 86.72% efficiency at typical load and up to 83% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
This PSU is backed with OCZ’s 3-year “power swap” warranty, the OCZ ZS Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- OCZ PowerWhisper™ Technology
- Internal 135mm ball-bearing fan
- Can power SLI™ and CrossFire™ GPU configurations
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 86% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- MTBF: 100,000 hours
- 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program.
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive - Black (Retail) @ £45.98 inc VAT
The CH10LS20 is LG’s internal dual format high definition drive that has the capability to read and play different Blu-ray formats. The CH10LS20 also reads and writes in three types of DVD formats in one convenient package – DVD+R, DVD-R and DVD-RAM. LightScribe gives you the added feature of creating customized labels that are etched onto a special coated LightScribe disc. Go Blu with the CH10LS20 by LG.
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 10x
- BD-R: 6x
- BD-R: 6x
- BD-RE: 8x
- DVD-ROM:16x
- DVD-R: 12x
- DVD-RW: 10x
- DVD+R: 12x
- DVD+RW: 10x
- DVD-RAM: 5x
- DVD-Video: 8x
- CD-R/RW/ROM: 40x
- CD-DA: 40x
- 80 mm CD: 16x
Was £52.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM @ £13.99 inc VAT
These great value drives deliver reliable reading and writing time after time.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £16.99 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
Was £94.99 Inc. VAT
ORDER NOW
- Weight: 700g
Was £28.99 Inc. VAT
ORDER NOW
- 5x HDD bays
- 1x FDD bays
Was £29.99 Inc. VAT
ORDER NOW
<center>
</center>
ORDER NOW
ORDER NOW
- Active PFC
Was £79.99 Inc. VAT
ORDER NOW
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 10x
- BD-R: 6x
- BD-R: 6x
- BD-RE: 8x
- DVD-ROM:16x
- DVD-R: 12x
- DVD-RW: 10x
- DVD+R: 12x
- DVD+RW: 10x
- DVD-RAM: 5x
- DVD-Video: 8x
- CD-R/RW/ROM: 40x
- CD-DA: 40x
- 80 mm CD: 16x
Was £52.99 Inc. VAT
ORDER NOW
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £16.99 Inc. VAT
ORDER NOW
