ACER 1682 + Bluetooth = ?
18 Oct 2002
Behind you... Naked!
Ok, I asked this before but got nowhere.
So, its bee na while and I htought I would ask again.
LapTop in Question is an ACER 1682
I have bought a Bluetooth adapter for it, that is for fitting INTERNALLY into it.
However, there are no instructions.
Now, I have stripped the Laptop down fairly much as far as I dare, and a bit more, but I cannot for the life of me, find where it can possibly go?
Has anyone actually managed to fit an INTERNAL bluetooth adapter into one of the things ?
I have looked on teh internet and I have found hundreds of other people in the same or similar boat as I, however I have not actually found a solution???
As a side note, I must add that I already do have a USB adapter.
BUT...
I dont want to use it... I want to use the internal one.
So, please dont mention the USB port or anythign to do with USB
Thanks in advance.
