Hi,
I'm in a bit of trouble!!! I have an Acer 7740g (5650 Mob ATI). Its stopped working.....
When I press the power button it loads the bios screen (Acer empowering people one), and stays there. Pressing F2 will say its loading settings.... but it never does.
I thought that the harddrive could be at fault so I removed it and rebooted. It has the same problem. I also removed the fan, and replaced the thermal paste on the GPU and CPU + another chip that had it on (maybe the motherboard chip) and cleaned everything up.
Needless to say I'm having no luck.... What do you recommend?
Thanks in advance.
Thanks in advance.
