acer al1916w - more problems
4 Nov 2004
Norn' Iron'
some of you will probably remember this thread
http://forums.overclockers.co.uk/showthread.php?t=17695092&highlight=acer+al1916w
the blurry-ness has gone and everthing is fine, looks like it was a loose connection - vga
i now have more problems
sometimes the monitor wont turn on, usually there is an orange light which comes on to indicate that there is no signal then the green light comes on when the computer is turned on
when the power is on (at the wall) the orange light doesnt come on, push the power switch on the monitor and still nothing.
if i turn the monitor off and leave it for 5-10 mins, turn everything back on at the wall, turn the computer on, everything is fine
has anyone else had this problem?
is it time to get it rma'd, i phoned ocuk and they told me acer have a 3 years return and replace warrenty
