Acer AL1916W review....
19 Oct 2002
Surrey
Acer AL1916W – By reddeathdrinker
User Pictures Of Monitor:
Colour Reproduction:
The following tests have been conducted after the monitor has been calibrated to the reviewer’s satisfaction.
Image 1: Colour Palette Picture – Very balanced picture, accurate colour reproduction. Nothing looks washed out, or over exposed.
Image 2: Colour Sands – Again, nice vibrant colours and excellent level of detail.
Image 3: Doom 3 Screen Shot – Clear picture, plenty of detail, even in the darker areas.
Gaming:
Gaming Observations: - Played a lot of Counter Strike:Source on this monitor, along with FS2004 and Far Cry. No noticeable ghosting is apparent in any of these games, which I'm running of a 9700Pro at the moment. Fortunately, the 1400*900 native resolution of this monitor is catered for by all my games so far....
Unreal Tournament Test Video (17MB) - Very, very slight ghosting when there is white movement on a black background, but not really that noticeable tbh.
Q.Would you consider yourself an avid gamer and would you recommend this monitor to a gamer? - I play a lot of games - the widescreen gives FPS games a nice, wide field of view, and for less than £200 inc delivery, I would recommend this to anyone with a tight budget to consider, or someone who wants dual-screens.
Panel Uniformity:
Black Screen - No noticeable backlight leakage in normal room conditions, very slight "blooming" round the edges if you look at it in a totally dark room.
White Screen - Nice, bright consistent white across the screen.
Image Clarity:
Running at 60Hz, with cleartype on, the panel is nice and sharp for both images, video and text.
Q. Does DVI make any difference to the image? - N/A, don’t have DVI
Viewing Angles:
Vertical: - No colour change throughout the vertical, readable to 170 degrees +
Horizontal: - Whites go a bit yellow at around 45 degrees, but is watchable right round to 170 degrees.
Movie Playback:
Matrix Reloaded Trailer (58MB, 640 x 346 resolution) - Good colour reproduction, very slight ghosting at full-screen resolution. Doesn't spoil the quality in anyway for viewing. If you want sharp, buy a CRT :D
General Movie Playback: - I watch a lot of both films and digital TV on this screen, and I have found no cause for complaint yet. The 16:10 aspect ratio plays movies with only a small black bar top and bottom, and 4:3 shows with vertical bars either side.
Nice review there mate, im upgrading my TFT in a few weeks. How did you get your games to support 1440x900? Iv just fired up UT2004 and Doom3 and 1440x900 isnt an option for resolution. Did you have to install a driver or anything?
Far Cry, FS2004 and CS:S/HL2 all supported it without any fuss. The resolution appears in the Video options screen in all of them. I'll be trying Doom3 in the not too distant future, the solution for it appears here
I am running the Viewsonic VA1912w which uses the same panel, but has dual inputs (1 x D-Sub, 1 x DVI).
Most modern games support running at widescreen resolutions either natively or via command-line, ini file or registry changes. It's changing the POV (Point of View) or Field of Vision that is sometimes not as strightforward.
the widescreengamingforum site is a great help and has a master list of games, listing which ones offer native support and giving simple instructions for those that do not.
I am running all my favourite games in WS lovelyness.
