*****Acer Aspire 5739G 15.6" LED Laptop Only £679.99 Inc. VAT*****
17 Oct 2002
Stoke
The Aspire 5739 Series notebooks continue the excellence of the Gemstone Blue design and pack the latest components and a multitude of entertainment technologies to give you superb high-definition multimedia performance wherever you go. You can also hook up to the Internet while on the move via a fast wireless connection. Play high-quality Blu-ray movies presented on a 16:9 HD display and enjoy theatre-caliber audiovisuals produced via a powerful graphics solution and 3rd Generation Dolby Home Theatre audio enhancement.
- Operating System: Microsoft Windows Vista Home Premium
- Processor: Intel Core 2 Duo T6500 2.10GHz 2MB Cache (800MHz FSB)
- Graphics: Nvidia GeForce GT 130M 1024MB
- Memory: 4GB DDR3 RAM
- Hard Drive: 500GB SATA (5400RPM)
- Optical Drive: Blu-Ray
- Screen: 15.6" WXGA CineCrystal LED LCD Widescreen (1366x768)
- Wireless LAN: 802.11a, 802.11b, 802.11g & 802.11n
- Ethernet LAN: 10/100/1000
- Sound Controller: High Definition Audio
- Speakers: Stereo & Subwoofer
- Expansion: 54mm ExpressCard Slot
- Card Reader: SD Card, Memory Stick, Memory Stick Pro, MultiMedia Card, MultiMedia Card Plus & xD-Picture Card
- Camera: 1.0 Megapixel
- Security: Biometric Fingerprint Reader & Kensington Lock Slot
- Connections: 3x USB 2.0, 1x USB 2.0/eSATA, 1x HDMI, 1x VGA, 1x RJ-11, 1x RJ-45, 1x Microphone & 1x Speakers/Headphones
- Battery: 6-Cell Lithium-Ion
- Dimensions: 372mm x 262mm x 38.8mm
- Weight: 2.7kg
- Warranty: 1 Year
BUY NOW
