https://www.tomshardware.co.uk/acer-predator-cg437k-p-4k-gaming-monitor,news-60365.html
Colour me interested...
Is this capable of 144hz 4k without having to adjust any of the image settings, or is it in the same boat as the other high refresh 4k screens that need an updated connection standard?
DP 1.4 can run HDR 10-bit 4K@144 Hz at 4:2:2 chroma. This is the settings the 27" 4K 144 Hz monitors launched last year top out at and I would run on my X27. You would have to run the desktop though at 120 Hz to not get the reduced chroma which sucks for text but was fine for games.
Reducing chroma to 4:2:2 so it fits within DP 1.4 bandwidth has nothing to do with an "overclock". Going beyond DP 1.4 bandwidth would be "overclocking", which this display doesn't do.
On another note:
https://www.youtube.com/watch?v=KXdhDhZ8xoA
And the bandwidth of 4K with DP 1.4 is 120Hz.
As Vega points out, overclocking the display is not related to the bandwidth of the interconnect between display and display driver. However a side effect of increasing the refresh rate via overclock is that more bandwidth is required and this may mean settings need to be changed in other areas (such as chroma) to accomodate the overclock and keep the signal within the limits of the interconnects bandwidth.
