Acer Predator XB323QKNV, 32in 4k 144hz
24 Feb 2021
Hi All,
I saw Acer Predator XB323QKNVbmiiphuzx is available to preorder online so I ordered it without seeing any reviews. I think this is the first 4k 32in 144hz gsync monitor for under 1000.
It says arriving on 23rd but I haven't seen any review except few on YouTube in Chinese. Any thoughts on spec? I will mainly use it for light graphic works and cod.
Thanks
With 90% DCI-P3 gamut that Innolux is lower end panel than AdobeRGB aiming AU Optronics panel in Asus PG32UQ and Viewsonic XG320U.
But there's no firm idea of even real release of those two.
Hard to know exact performance, but at least 28" version of Innolux has good contrast for IPS and response times are quite near top.
Thank you for the replies.
Asus is very expensive, is there any other 4k 32inch with high refresh rate coming soon?
My current monitor is 4k 28inch but only 60hz. I really want to stick with 4k, and decided to try 144hz and 32inch for cod.
I think i might go with XB323QKNV, its got something called VisionCare. I have eye problem so hope it helps.
Will put a review when i get it on 28th August.
Hi All,
Thanks
How is it ?
Fingers cross you got one of the allocated ones. I saw the reviews of one of the new 32 4k 144 panels and they look pretty good
got an email saying we’ll email you as soon as we have a delivery date... now thinking of AORUS FI32U, but its not GSYNC and read somewhere some had dead pixels.
All monitors can have dead pixels sadly. I do wonder if some are better with there checking and send out less monitors with dead pixels etc
Ahh that’s a shame. It will be interesting if it’s better then the ASus 1k equiv. that ASus seems worse the gigabyte 32 4K
The Acer one I saw reviewed in CustomPC mag was £700 I think, or was it PC Gamer forget which mag now.
Acer QOS is pants though.
I think it’s also sheer luck with regards to quality control. All of my acer ones over the years have been fine luckily.
