ACER V223WBbD 22" DVI WIDESCREEN LCD MONITOR ONLY £126.99 inc VAT
17 Oct 2002
Stoke
*** *** Acer V223WBbd 22" Widescreen LCD Monitor @ £126.99 inc VAT *** ***
The Acer V223W is the essence of versatile productivity, bringing to the professional office and media world the perfect combination of high definition performance within a slim design format for the ultimate viewing experience. The V223W combines the latest Widescreen Panel technology, efficient lean design with full consideration of high Display Performance per pixel, this is an irresistible opportunity to join the widescreen trend for PC Displays.The V223W provides the ideal technical features required for multi-tasking and image precision, the intelligent 22” widescreen display supports also the latest operation systems which require high definition pixel per inch for specialised professional applications. The V223W is truly a cost-effective solution driving versatile performance for media lovers and professional business environments.
- Screen Size: 22" Widescreen
- Resolution: 1680x1050
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: *506.0mm x 399.0mm x 180.0mm
- Weight: 5.2kg
- Warranty: 3 Years
Only £126.99 inc VAT.
ORDER NOW
