I've copied this from the support ticket I opened, but thought I'd see what you guys thought.
My monitor seems to have developed an issue with its refresh, and I have no idea what's caused it. I was playing a game before, and upon exiting, it changed down frequencies as it normally does as I run my desktop at 100Hz, compared to 144Hz for games. For some reason the monitor didn't seem to like that, and has now developed a flicker across 2/3rds of the screen.
This isn't related to the cable, as it now seems to do it even with out the display port cable plugged in, and I have plugged it into my Macbook with a different DP cable with the same results.
The problem isn't massively noticeable at 100Hz +, but down at 60Hz it is unusable, almost like half of the frames aren't being rendered.
I've tried resetting the settings, unplugging it and leaving it for half an hour, but I get the same results. So just wondering if there is any advice that you can offer?
