Hi,
Just bought the Acer XR342CK and was wondering how to use the USB 3.0 hub on the back of the monitor?
It came with a USB-C to USB-C cable which I have connected to the USB-C Port on my Rear I/O, but that doesn't work, as no peripheral connects/can be found.
..And it's not like that is for output TO the monitor because there is no option for that in the 'source' section. So it's the only thing I can really think of it being used for.
I thought it would be a USB-A to USB-B Cable or something like that?
Plus, the manual says to plug USB cable there and on the manual, its not a USB-C port like it is on mine.
Thanks in advance
Thanks in advance
