Acer XZ271 Ghosting (i think)
17 Jan 2017
Hey Guys
I have a problem with my Acer XZ271 144hz Monitor
I'm getting a kind of Ghosting effect but only on dark spots and only when I pan the camera
It's like anything that a really dark or black flickers/smudges if I pan the camera but is fine if I am stood still
Also, it's not on everything, If I play Overwatch everything is fine but if I play Dark Souls 1 it's really bad, also almost anything played on my PS4 (Via HDMI) does this too (but the ps4 is fine if it's on my TV) I also noticed that if I play my PS4 via the remote app it doesn't have this problem but is only in 720p so kinda crappy quality
Does anyone have any idea at all what the hell is going on, I'm finding it very hard to work out what the problem is let alone solve it (I've tried every setting I can and nothing seems to work)
(if it matters my rig is an Intel Core I7 7700 with a GTX 970 4GB)
Any ideas are very much appreciated
If it's the VA panel version then what you're seeing is typical behaviour. Running the PS4 to monitor at 60hz will just make the blur from dark transitions worse.
Hmm, we already had this conversation in January. Did you manage to try the 60Hz via DP on the PC? Or is this a separate issue?
