Acoustic Energy Aego M 2.1's advice
24 Nov 2003
London
I am looking into buying a relativly cheap 2.1 PC sound system for music games and occasional DVD; after reading through a few threads here the impression I get is that the Acoustic Energy Aego M 2.1's seem to fit the bill (small quality speakers, good build quality sound for a PC based speaker system, relatively cheap)... They will be used in my bedroom/study room which measures 15 x 11 feet.
A "few" questions if you please:
1) Where can you buy the wall mounts for them/what are they called?
2) Will the extra centre speaker connection give you a dedicated centre chanel (like when watching a DVD and hearing speech from centre speaker only)?
3) Is there anyway an old record player can be plugged into the base box for sound output through speakers?
4) Can headphones be plugged into the system?
5) I use an Xfi Elite Pro card, what would be best connectivity for these speakers?
Sorry for all the questions, any help/recommedations would be much apreciated
S!ap
1) I doubt you can buy wall mounts there the wrong type of design and to deep.
3) it'd depend on the connection I suppose.
1) You can get official mounts from hi-fi shops for ~£12.
3) If you get a phono>3.5mm converter, you should be able to plug it into the front. You will probably need a phono stage though.
4) No
5) 3.5mm jack.
Thing is these are just speakers, not the 'hubs' that the logitechs/creatives are. The sound better for it too!
