Acoustic Padding worth it?
9 Apr 2006
Hi i was wondering if anyone has used "Akasa AK-PAX-2 " I've got an eclipse, with some low noise 120mm Fans in it. But i wanted to get the noise down as much as possible. Does the acoustic padding make much difference and is it really worth it??
Don't do it! It really doesn't help with the sound that much at all. However it can really increase temperatures. And if you ever want to sell the case in the future, tough, as the stuff is nearly impossible to remove.
when i had the eclipse i bought that akasa sound dampening kit...didn't make any difference at all (to my ears anyway)
It stops the case panels resonating, if they do like mine did on my eclipse. It didnt raise my temps in the eclipse as the air doesnt stay in the case for long due to the layout and 120mm fans front and back. IMO it isnt really worth it as its quite expensive but i just thought id give it a try.
Mark
There are easier ways to stop the case resonating, and cheaper, elastic bands and blue tac are the tricks of the trade. ;)
So does it reduce the noise levels any then? i dont quite see how it would as the foam pannels dont appear to stretch across the whole of the pannel :confused:
It does nothing for 99.9% of people. It will make your computer run hotter, that happens to everyone.
It is rubbish, takes almost a day to remove and is just terrible :mad:
I have seen a case with it in and it made no difference to the noise that was coming from it! The temps were quite high too.
Do not do it!!
I spent £30 on some for my Antec Sonata a while back and it made absolutely no audible difference to noise but did manage to put my temps up by at least 5 degrees :(
While i certainly am not a fan as such, i like it for rigs im going to watercool, its a nice base to mount pumps, there are cheaper and better alternatives, rarely to they look as tidy.
I use the bottom part of a kitchen sponge for my pump - the yellow bit. :)
For the love of God, Don't do it!
I'm STILL trying to take the crap off my Praetorian. Makes bugger all difference to sound, but it will increase your temps by at least 3 degrees.
