Acrobat Pro X - Slow Opening
5 Nov 2010
Hertfordshire
Hi all, i have a really annoying issue with Acrobat Pro X that i was hoping to get some help with.
Basically, if i boot up the PC and open some PDFs, it's fast/normal and will continue to be for a while.
However, after a while, later on in the day if i go to open a PDF it will just take ages (10-15 seconds).
I can't pin down if an application is causing it, it just seems to be random. I've had days where it's been fine as well.
It happens with local PDFs as well as network stored.
I've tried a complete fresh install of Acrobat Pro but to no avail. Also tried the Adobe forums suggestions for others that are having similar issues.
Next step i fear is OS rebuild, but until then i'm open to suggestions. I'm not sure if there is a dodgy cache issue with Acrobat Pro or something?
