Hi there,
I'm having problems backing up with acronis v11. I have two computers which backup to a main server. One computer is xp, one is vista, they both have acronis v11 installed and take an image which is stored on the server using a folder share.
There is a fair amount of data, 60gb and 120gb each week plus a daily which is 1-2gb. The problem is that I just can't get acronis to max out my network (100mb), it just sits at 25%.
I am unable to work out where the bottle neck is, all the drives are fast, the cpus are dual core and don't even break a sweat, there's plenty of ram and if i try backing up to a second drive rather than a network location it flies along.
The network itself is fine, if i manually transfer a file from any of the computers it maxes out the network no problem.
Compression settings don't seem to make any difference.
I'm at a loss, any ideas?
Thanks
Thanks
