I've just got a copy of Acronis True Image Home, and purchased the CD Key to unlock it. Program seems really good, however I need some help with how to do a backup.
First problem I have it because I registered the trial version, I don't have a bootable CD. And secondly, I'm not sure on how to create a full system backup. I want to create a full system back up so I don't have to go through the hassle of reinstalling drivers etc when I install Windows. This way I can just chuck in the backup DVD and image my PC.
I'm looking at the program now, and it has a program called "Bootable Rescue Media Builder" Do I use this to create a bootable CD. And then use the True Image program to create a full system backup?
I've had a quick look and thats how I'm guessing I do it? Also, I select my DVD to burn the image to but it wont let me, so do I just create the image in a spare folder and burn the image to data DVD using Nero?
With that you can create, restore, etc without going into OS. Handy if Windows is corrupted, etc.
To create on DVD/CDs, think you need to tell it to split the images.
, my DVD drive doesnt show up
