Acrylic bath repair
28 Oct 2003
Worthington-on-sea
Arrrgh!
Teenage daughter put the top from a bottle of non-acetone nail polish remover down on the edge of the practically brand new acrylic bath in our new master bathroom and it's melted a ring mark into the top coat of the bath. It's right in the middle of the side so highly noticeable. Apart from the fact my wife is going to do her nut when she gets home, how the heck am I going to repair it without it looking awful until the end of time?
Also, what the hell is in the Cutex nail polish remover that does such damage? Ingredients list is
Methyl Acetate, Aqua (Water, Eau), Butoxydiglycol, Cocos Nucifera (Coconut) Oil, Propylene Carbonate, Sodium Acetate, Propylene Glycol, Benzophenone-1, Denatonium Benzoate, Parfum (Fragrance), Linalool, Coumarin, Limonene, Citronellol, Blue 1 (CI 42090)
Any help or advice greatly appreciated!
No repair suggestions sadly, though I'd start by searching online for acrylic bath repair kits. I know enamel ones you normally can find repair kits with a bit of filler and an enamel paint pot.
Google sez:
Is Methyl Acetate the same as acetone? Methyl acetate and acetone are two different chemical compounds, however they are used for many of the same applications, and methyl acetate is often used as a substitute for acetone
So that's a bummer, it's very similar to acetone which is evil stuff to spill.
Magic man may be able to do something.
Not that it helps but this why housing associations prefer metal baths, they’re easier to repair.
My wife originally wanted a metal bath. I strongly vetoed it because they're cold and generally horrible.
Nope. They're really nice. What you do is put loft insulation around them. They feel better than a plastic bath if they're installed correctly, they don't creak or deform and they're miles easier to clean. Sorry.
If it was me, I'd claim on the insurance and replace it. With an enamel bath. Then luxuriate.
