I've taken the plunge and bought some acrylic and tools. Went with the 13 mm Monsoon kit as I planned to go 13mm acrylic in line with my current soft tubing. Then I found out that the EK fittings are 12/10 instead of 13/10 so I bought 12/10 acrylic. Am I going to have problems with the mandrels being sized for 1mm OD larger or will I be ok as it's close enough and the ID is correct?
Many thanks in advance.
Gareth
Gareth
