- 6 Mar 2017
- Sunny Bournemouth
Hi guys/girls, am looking to upgrade from flexy too hard tubing and was just wondering how much flex there was in acrylic tube - if any. I have searched the forums, with little luck, and apoligise if this has been answered before. I'm thinking of using monsoon ev2 compression fittings (16mm) with the least amount of rotary fittings visible. I understand with copper that with bends it allows a bit more flexibility in the pipe than using fittings so was wondering if, within reason, its the same here. What I'm concerned about, the fittings being fixed points is that to join them I will have to insert the tube at an angle and in doing so will fluff the o rings. Also any suggestions what rotarys will suit monsoon fittings the best (visually) - bitspower have the largest selection here but are expensive and often with just 1 in stock here. Many thanks in advance.
