Acrylic WaterCooling Advise
17 Nov 2013
United Kingdom
Hello
As above I am after some advice regarding watercooling with Acrylic (Rigid) tubing.
I have fitted many watercooling loops using flexible tubing but this will be the first time I use Acrylic.
I will be working in a Corsair 540 Air
280mm Rad on top
360mm Rad on the front
CPU waterblock
GPU waterblock
And my pump and res are in the back cabin
The tubing I am using is Primochill along with Revolver fittings
Do measure, measure and measure again.
Do make sure the tube is sufficiently heated before you go to bend.
Do bend in a smooth motion.
Do buy more than you think you need.
Don't burn the tube.
Don't bend with your bare hands.
For my routing I can either have the ports on my 360 Rad at the top or bottom. It will be harder to bleed with the ports at the bottom but will look better for the tubing runs. Anyone had any issues with a rad mounted with the ports on the bottom
